Washing Machines Logo
Deena Cloe Posted on Jun 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code e21 on frigidaire affinity washer cleaned pumped and ran a rinse cycle it did fine put clothes in to wash it ran for 10 min. then stopped.
JP Meneide
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Frigidaire Master 483 Answers
  • Posted on Jun 20, 2015
JP Meneide
Frigidaire Master
Level 3:
Dedicated:
Answers
483
Questions
Helped
177878
Points
2858
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
  • Yvonne Sanchez
    Yvonne Sanchez Aug 30, 2019
    I did that I replaced the pump it still doesnt drain each wash. I have to remove some water then itll drain
Boyd McSwain
Level 2:
Habit-Forming:
New Friend:
  • Expert 64 Answers
  • Posted on Aug 31, 2019
Boyd McSwain
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
69584
Points
106
Try googling error code e21.
5 Related Answers
sagacious
GORDON'S APPLIANCE SERVICE
  • 283 Answers
  • Posted on Feb 08, 2008
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
a75737b.jpg Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 21, 2008
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Anonymous
  • 1294 Answers
  • Posted on Apr 05, 2009
SOURCE: Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Anonymous
  • 552 Answers
  • Posted on Mar 08, 2011
SOURCE: My LG WM2487HRM has the
The pump is on the lower left of the front
Frigidaire front load washer e21 error appears after running about 20 mins into the wash cycle,i check the clothes they are still wet,although no water is still left,i go to the spin only cycle to get the...
Hello debbiecantu1 - Typically error code E21 indicates an issue with the water not pumping out fast enough. Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
My frigidaire washer has e21 error code and wont start
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
My fridgedaire affinity washing machine washes the clothes, then drains then starts to do a light tumble right and left. it never goes into a rinse cycle. It finally stops and shows an error code E10. I...
it could be that your rinse water valve has gone turn off all power and take the top off you can see the water valves at the back of the machine if you have a multi meter you can test the valves for continuity if ok then your filter might be blocked try the filter first
1helpful
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
2helpful
2answers
Error code E21
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump. if no voltage Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
8helpful
3answers
E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
5helpful
3answers
Affinity E21 error
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
