Machine quit a few minutes into a wash cycle then started beeping and beeping and beeping and beeping.
Unplugged it to try to reset. Now when it's plugged in it sounds like the door lock is engaging and then it shuts off - except it beeps and beeps and beeps and beeps.
Unfortunately the laundry wasn't out of balance. That would be too easy to fix and wouldn't cost anything :-)Unfortunately the laundry wasn't out of balance. That would be too easy to fix and wouldn't cost anything :-)
You can't post conmments that contain an email address.
Please do the following to fix the problem:
1. Power cut: First, unplug the washing machine and wait a few minutes.
Then plug it back in and try starting the app again.
2. Resetting the washing machine: If turning off the power alone does not solve the problem, you may need to reset the machine.
To do this, press and hold the Quick Start button for 5 seconds to reset.
Then try starting the program again.
3. Checking the water level: Make sure that the water level in the washing machine is correct and that the water supply line is connected correctly.
If the water level is low, it may cause "Err 105" error.
If your Bosch Avantixx6 VarioPerfect washing machine is beeping and the light is cycling through the spin cycles without any other noise or action, it could indicate a potential issue with the machine. Here are a few troubleshooting steps you can try:
Check for error codes: Some Bosch washing machines display error codes on the control panel when a problem occurs. Look for any error codes or error messages that may be displayed. Refer to your washing machine's manual or the manufacturer's website to understand what the specific error code means and how to address it.
Check the door/lid: Ensure that the door or lid of the washing machine is securely closed. If the door is not closed properly, the machine may not start or may display an error. Open the door and close it firmly, making sure it latches properly.
Check water supply: Ensure that the water supply to the washing machine is turned on and there is an adequate water supply. If the machine doesn't detect sufficient water, it may not start or may display an error. Check the water inlet hoses and the water supply valves to ensure they are properly connected and not blocked or kinked.
Power cycle the machine: Turn off the washing machine and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This power cycle may help reset any temporary glitches or errors in the machine.
Contact customer support: If the issue persists and you are unable to identify the cause or resolve it on your own, it's recommended to contact Bosch customer support or a qualified appliance repair technician.
Have you tried unplugging the power and leaving it unplugged for a few minutes to try and reset itself? If that doesn't help then please provide the model number - should be located on the door somewhere.
