Microwave Ovens Logo
Karen Bent Posted on Jun 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know how long to dry herbs. There is a drying setting on the oven
Lawrence Oravetz
Level 3:
  • Microwave Ovens Master 10,558 Answers
  • Posted on Jun 18, 2015
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2695757
Points
29284
You dry at 200 degrees. Anything higher will destroy the flavor of the herb. Usually it takes 4 to 6 hours or until the leaves are dry. Then put them in a blender to chop them up to a fine consistency. I sun dry my basil instead of oven drying. I have a dehydrator , but it takes 24 or more hours to dry them so I don't use it much.
I have a turn knob that seems to be getting a little sticky on microwave. the knob is used to set the amount of time I want. How do I fix?
Turn off the microwave and use some electrical contact cleaner. Let it dry out till smell clears. If unsure leave it to dry for 30 mins then try. You can get contact cleaner from hardware stores.
Paint peeling inside microwave
After removing any chips, the area will have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would suggest you let it dry overnight with the door open before using the oven.
Wife spilled water in micro model jes1651sj02 blew breaker dried spill some water still inside
Remove and use a hair dryer to dry the boards, it is important that ALL the water present within the board must be dried out.The board also can be removed and dried
Please check this link: Water in set
My radiators are getting warm when my heatings not on. Any ideas??
You can check your microwave for possible LEAKS and make sure there are no FOOD particles blocking the oven's fan system To check for leaks, place a DAMP paper towel around the door seals and place a glass cup of water in the microwave. If there are leaks of microwave energy you will find DRY or WARM areas on the paper towel. BE CAREFUL not to peer or watch the test, done on level HIGH for 1 minute. Microwaves may cook the vitreous humor (liquid in eyeball,) just like it would an egg. If the towel is dry or hot ANYWHERE after the test, TOSS the microwave. Your safety is not calculated by the cost of a new oven.Let me know how this goes; I have tested many older ovens and have found quite a few leaky ones.
Sciencewoman
The Cook Time I use to work, not it wants a code and if I put in a number it will start. But I can't set a cook time or power level. The Cook Time II works ok, except I can't use the number 1; defrost...
Is it possible that some cleaner got into the controls? That'll kill them quickly.
Hopefully it will dry out on its own. I'd unplug it overnight.
If not, then either there is moisture on the control board (which can be dried or allowed to dry) or in the layers of the membrane keypad.
But the membrane keypad may not be available any longer. It is part number WB27X287 and if it still available, it may take a week or so to get it, it will probably be about $150-180, and you can try to order it from the Pros here, the Sears Parts Direct Web site image-4235112-10659157 or from Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We do board repair, so let us know via our site if we can help further.
I have dried on grease stains on the bottom of my pots and also there is a whitish colored film that remains after the pots are washed and dried. I need to know how to clean them.
Spray Oven Cleaner all over stains, SEAL inside plastic garbage bag, leave bag for 2 days, wash pans with scrubber pad, stains should be soft and come off with a little rubbing.
1helpful
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
My electric dryer is takeing to long to dry clothes.
If you are experencing longer dry times, the following link will explain what to do:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Read through the link provided and let me know if you have any questions. Please post back with a model number if you do. I hope this helps you.
12helpful
2answers
PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
