Question about Maytag MMV4205 Microwave Oven
Where is the main fuse located - Maytag MMV4205 Microwave Oven
    Top Expert:
  • Maytag Master
  • 10,875 Answers
Inside the case
Posted on Jun 17, 2015
6ya staff
SOURCE:
Where is the fuse located
The fuse is generally located very near where the main power wires. It is most likely located inside so the lid must be safely removed and the unit must be unplugged. The power wire will run directly to the fuse in a block. Replace with the same size and type.
Sep 21, 2012 | Goldstar MA-1012 Microwave Oven
Where is the fuse located at on Where is the fuse located at on a Frigidaire...
The main fuse is on the power board. Right where your AC cord is.
Apr 26, 2012 | Frigidaire Microwave Ovens
Locate the fuses in jvm2070
Fuse is located on the right side under the keypad, follow wiring to main board, should see a small fuse clipped in, pop it out and replace with same current rating. Before you do this unplug microwave, and discharge high voltage capacitor "silver and rectangular in shape" under plastic flap near fuse. One thought the voltages are lethal when running.
Mar 14, 2012 | GE Profile Spacemaker Over-the-Range...
Okay you said it was probably a fuse so where is the fuse located?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 19, 2011 | Kenmore 63792 Microwave Oven
Were is the fuse located?
If you remove the power from the machine. Remove the cover and the mains lead is directly connected to the fuse.
The fuse id blown MUST be replaced with an IDENTICAL fuse.
Feb 03, 2011 | Sharp R-1405 / R-140 Microwave Oven
Kid put mom's curling iron in microwave. Turned it on and now nothing. No lights, nothing. Is there a fuse to check? Maybe it is too far gone? Thanks
there is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations
Jan 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
I need to locate the fuse panel. Where is ti?
Hope this helps.
Nov 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the main fuse?
Hello :
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
The picture bellow is showing a blown fuse .
please rate .
Mar 29, 2010 | Kenmore 80412 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
164 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
