Sounds like a vacuum leak has developed in the intake system. While the engine is whistling, using a spray bottle with water and on the mist setting, spray along the intake manifold area and vacuum hoses to locate a possible leak.
I don't think your whistling is related to your chain adjustment. What else might be whistling ... helmet ... ???Did you change anything else? Was your chain loud before and possibly covered the noise you are now hearing?
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
That most probably seems to be a future issue with your color wheel, it's starting to go out, you need to identify which one you have before you purchase one, there are two kinds, one with a gold bearing and another one with a silver bearing
a couple of things could make the tv chassis whistle 1 coud be dry solder joint probably on power capacitors 2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
