SOURCE: programming help
Try to buy another manual (univesal remote control) because its not easy for you to get the codes if it will not work the write to us again.
SOURCE: Remote randomly works. 27" Symphonic TV... but remote works on other Symphonics in the house
I have the same TV & problem.
The problem is Not with the remote but with the remote receiving circuit in the TV. The remote works once in a while.
Anyone have the TV schematic diagram?
SOURCE: philips universal remote codes for symphonics tv
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
