Invacare Pronto M51 Power Wheelchair Logo
v
vern weller Posted on Jun 16, 2015
Light come on controller no flashing code lights joy stick does not work
gnsdance97
Level 1:
New Friend:
  • Contributor 68 Answers
  • Posted on Jun 25, 2015
gnsdance97
Contributor
Level 1:
New Friend:
Answers
68
Questions
0
Helped
36706
Points
82
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
The light on my quantum 610 joy stick pad is flashing and the joy stick is not working
hi, whats it flashing ? , its telling you whats wrong , just make a note of what lights are flashing etc
VSI Flash Codes
regards
Rob
gewizrepairs.co.uk
How do abtain code to stop flashing lights
Hello jimmy dale pierson,if you contact a Repair Shop.Give them your explanation & ask:From the info I have given you,can you give me a price for repairing the Fault & what is it please.I hope that helped you,Colin
Lights on joy stick controller blink on and off and chair wont move
Cezna Are the lights that are blimking the battery level lights or they the speed level lights. If it is the speed level lights then the chair thinks you still have the charger plugged in. If it is the battery level lights do a certain number of lights flash 3 lights flashing 4 lights flashes etc this is the flash code and will tell you what problem you have. It could also mean that you are in lockout or sleep mode If you have the VSI joystick then turn on the power immediately push the joystick forward and hold until you hear a beep then mmediately push it to the rear til you hear a beep then immediately let it return to the center position. If it was in sleep mode this should wake it up. Hope this helps you
On the joy stick all the lights flash but it doesn't work
This really needs more clearification. What is the nature of the flashes. The flash codes are used for diagnostics. If you know what the flash code is you can generaly find the problem
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
