Does the freezer get cold? To what temperature? Is the lid closed tight? What do you have the temperature set at? Is it set to zero or below? Is it an automatic defrost freezer? If so, have you set the auto defrost to off? If you turn thee temperature all the way to the lowest setting, does the beeping stop after awhile? Usually beeping means a lid/door ajar or a temperature problem.
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
The board is telling you that there is an issue. Usually there is a series of beeps indicating the issue. the reset button is on the board, near the top of the board and is small and white. press it to reset.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
freezer not working on ariston...
Solve
freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
