Ativa MD1250 12-Sheet Cross-Cut Shredder - 4.5 Gallons - 6.6 fpm Logo
R
Robert Beck Posted on Jun 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an ativa shredder model MD 1250. Became jammed on some staples. Reversed it and pulled it out but no the auto shutoff won't work Is it fixable? The shredder still runs.
John Mock
Level 3:
  • Master 932 Answers
  • Posted on Jun 15, 2015
John Mock
Master
Level 3:
Answers
932
Questions
Helped
273680
Points
5591
Robert,
Double check that you do not still have any paper that may have become stuck in front of the sensor for the auto shutoff. If there is something in front of the sensor it will keep running.
Ativa Shredder. It seems to be stuck in reverse?
Question edited for clarity and spelling of maker 'atvia' to 'Ativa'.
If it is only running in reverse the most likely cause is a faulty switch as the switch just reverses the polarity of the power to the motor. Also check that nothing is covering the proximity sensor in the throat of the shredder.
The shredder will only constantly run in the "Reverse" mode. The trigger located in the center of the feed entry slot, which activates the shredder, may be blocked. To clear it, you would need to insert an index card or file folder (i.e. rigid paper or cardstock) in the center of the feed slot and apply force.
Jammed ativa shredder, works in reverse, won't go into auto.
JustAnswer https://www.justanswer.com > office-equipment > c79...
Mar 24, 2019 - Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from ...
1 answer · Top answer: Let the shredder cool down if the shredder has been running continuously for a long time. ...
Why does my paper shredder operate in reverse only? '
KnowledgeOwl https://fellowes.knowledgeowl.com > help > why-does...
Apr 13, 2022 - This likely has to do with the auto run sensor of your shredder not being engaged correctly. On small shredders, the sensor is normally a ...
The shredder runs in "Reverse", but not in the "Auto /On" mode.
2answers
I have a AtivaM1250 shedder & the middle light on the panel with the lines will not go off which causes me not to be able 2 use the shredder What must I do 2 get this light out or is the unit trash
Please make sure that you've emptied the shredder bin because a full bin can stop further shredding. Also, cleaning the shredder teeth to stop paper jams would be good as well.
Thank you.
1helpful
1helpful
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
How do I empty the wastebasket on the Ativa MD 400 shredder?
Just pull the waste container out and dump it and reinstall it and make sure it goes all the way back in.
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
I need a fuse for our Ativa AT 1250 shredder ..
Read ITS RATING or remove it and buy from electronics shop.
2helpful
3answers
Shredder won't turn on
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
1helpful
2answers
STAPLES MODEL#SPL-826XSHREDDER
Cleaned the sensors with warm water and Q Tips. Works fine now..
For Staples shredder model #SPL-826X.
Thanks!
Top Ativa Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
