The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
hi Ali, do you have any photos for this cooker EFa600H? I need front of this cooker. because i have in my new home but i can't used this apliance because all numbers ale clean, someone clean this oven very very strong and remove all signs:)
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe! 2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit. 3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable. 4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above. 5. Note that the hinges have no means of adjustment. If not working properly, renew them.
