t5o permantly delete facebook i did it in the history tab! ZI wasnt trying to tho...i was romoving one by one my facebook logins and then somehow ive permantly removed the link from my pc..I got to sites with facebook button and still cant log in thru them..That was in history somewhere
since it is posted in the router problem, i assume it is blocked from the router configuration page...but i wont exclude the possibility that is is blocked from your unit's os..anyway if its blocked from the router..you must access the config page of the router..usually the default is 192.168.1.1 but if you can access it is likely that they changed it to their preffered setting..even if you know the ip to access , it would be useless if there's a password..your next step is to reset the router...look for a small hole at the back of the router and insert a pin or something to reset it by push hold it for maybe 10-20secs..then you should be able to access it by default 192.168.1.1 or 192.168.0.1
First, make sure that the network you are on is your network. Next,
check any firewalls that the administrator has set up on the network. If the administrator has set up any settings to block either youtube.com particularly, or other websites like youtube.com (video streaming, etc.), then no computer on the network will access the site. If this is true, then the administrator must log in and change the settings manually. Lastly, check to make sure you are using a supported browser, or that your browser is not blocking either the website, or anything on the website that would keep it from running (such as an ad blocker). If neither of these things is true, then it would be best to call your internet service provider to assure that your router is performing correctly. Best of luck!
If you have any advertisement blocker or any kind of script blocker, sometimes we accidentally click block to Google.com or youtube.com because of scripts it takes it as a scripting sites and malicious sometimes because of advertisements. If this helps try to rate my help. Thanks
