SOURCE: ocr folder
The software you need is Abbyy Sprint OCR. If it's not installed, I suggest running the printer setup again, making sure it's selected when you get to the software list. Perhaps you unchecked the box when you ran the installation the first time, or didn't know what it was and uninstalled it from your computer. You may be able to find it by hunting through the CD, but it will probably be easier to run the setup again.
SOURCE: ocr WHERE DO i download the soft ware for my lexmark
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Here is the link to download the software
SOURCE: Lexmark X2500 driver is missing OCR software
Sometimes companies only support only the basic drivers. The OCR software is on the CD (s) that came with the printer. Suggestion. Try to order the original CD from Lexmark., or search Ebay for programs that have OCR capability. You can use OCR programs from other vendors as long as they are stand-a-lone programs. Just make sure you have the original disc so as not to infringe on copyright privileges.
Note: you can buy OCR programs. Check Ebay and Amazon. They are usually better that the programs that come on the OEM disk.
Cheers.
SOURCE: Need lexmark 8300 OCR software
Try this and let me know http://download.cnet.com/Lexmark-8300-Series/3000-2116_4-189010.html
To scan documents for editing and saving as PDF file, you will
need to install the Lexmark OCR scan software on your computer. The Lexmark
scan software (no downloadable version) is only available on the installation
disc that came with your printer. If you lost the disc, please contact Lexmark
Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
