Adobe Photoshop 7.0 for PC Logo
a
adiii Posted on Jun 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i verify the directory path where adobe photoshop 7.0 is located
Michel Tritz
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 103 Answers
  • Posted on Jun 14, 2015
Michel Tritz
Expert
Level 2:
Night Owl:
Answers
103
Questions
Helped
18262
Points
168
it is located in program files/adobe/
cheers
mich
Xavier Prathap
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Jun 15, 2015
Xavier Prathap
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
16735
Points
28
Right click on the shortcut icon of Photoshop 7.0 -> click properties..
In the text box named " Target " you will see the complete path..
its usually c:/program files/Adobe
OR C:/program files (x 86)/ Adobe (if u r using 64 bit system)
Sardar Yasir
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Dec 19, 2017
Sardar Yasir
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
6246
Points
63
Just right click the icon and then properties and you will get the directory path
3answers
How do i verify the directry path where adobe photoshop 7.0 is locate
If you have shortcut on desktop - Right Click - Property and see the target, you can also open file location from here
4answers
Directory path where the photoshop 7.0 located
C:\Program Files\Adobe\Photoshop 7.0
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
1helpful
Photoshop file info data cannot be read. How to fix it?
hi,
when you have your document opened, look every layer to find little yellow triangle(s), witch means that there is a problem with this(those) layer(s), it can be (more often) the text layers that have fonts that you don't have installed, or a reference file that has been moved from original path.
hope you'll solve that !
cheers
mich
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
3answers
When attempting to start Adobe Photoshop Elements 2, I get this message " Could not complete your request because of missing or invalid personalization information." Using a PC running XP home service pack...
OK, loads of different fixes for this, have fun.
These errors are caused when a version of Photoshop CS is already on the computer, such as a beta copy, or if your registration information file does not get written properly or is damaged. If multiple copies of Photoshop are in the Applications folder, or if a beta or tryout version is installed in addition to the regular version, the system and Photoshop may confuse which files to use to verify personalization. This confusion can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder in alphabetical order. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
Do one or more of the following solutions:
Solution 1: Remove and then reinstall Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's splash screen upon opening Photoshop, you may have another version of Photoshop CS on the computer. Empty the trash, remove the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
To remove and then reinstall Photoshop:
2. Delete all Adobe Photoshop CS folder(s) in the Applications folder.
Solution 2: Remove and then reinstall Photoshop in another location.
If you uninstall and reinstall and still get personalization errors, or if you cannot locate an installed copy, uninstall any copies you find, empty the trash, and then remove Photoshop, and then reinstall Photoshop in another location that is alphabetically in front of any other installation.
To remove Photoshop and install it in a new location:
1. Move any personal files from the Adobe Photoshop CS folders on the hard disk to another location.
2. Delete all Adobe Photoshop CS folders in the Applications folder.
4. Create a subfolder in the Applications folder, that is named differently from the default Photoshop install folder (Adobe Photoshop CS), and is is alphabetically in front of the other version of Photoshop, such as \Applications\aaaa\Adobe Photoshop CS.
5. Reinstall Photoshop CS and select the new subfolder (created in Step 4) as the install folder when prompted for the installation location.
I know its a lot, but Adobe is a complicated program:) Source(s): http://kb.adobe.com
2helpful
2answers
Error 1304
no problem...
se HERE...
folow the instructions, and you will be ok :)
29helpful
9answers
How can i download adobe photoshop free
U cannot download photoshop 7 directly from adobe servers though its there,
u can call uip Adobe, give them a valid sr no for photoshop 7 & they would send u an ftp link in your email.
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
