Question about Plumbing
My fawcet hasloosened up from the counter
Faucet has come loose at the counter
  • 18,154 Answers
Take everything out of the cabinets under the sink. Lay down some towels or a pillow, Get a flashlight and look up under the sink. You should see one of two retaining fasteners that are really big nut type fixtures on the bottom of the valves. They are above where the hose connects. Tighten those.
Posted on Jun 13, 2015
6ya staff
SOURCE:
Installed correctly last night, do not have even a drop of water at the Fawcett. 40 psi on tank
First check the faucet strainer, right on the faucet. Then make sure the cut-off under the sink is on. Faucet strainers stop up easy.
Jun 30, 2015 | Plumbing
Grohe alira loose on granite counter
Needs to be tightened from under the sink, may need a right angle faucet wrench, they are about $10, or you can try and snug it up by hand, hope this helps?
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
New Danze D308340 faucet leaking under handle. Can't remove the capto get to retainer screw, which needs tightening.
is the capp colored red/blue? if yes, take a picky pointy knife (lmao) and peel it off,pick it off,The leak is probable just the adjustment under the handle, the fawcet originaly came with a tiny spud wrench (made like a 2 pick pitch fork, if you cant find one, i use a pair of channel locks pliers, but first wrap rubber glove or cloth around the top of fawcet so you dont scratch it.How old is this fawcet?
Nov 12, 2011 | Plumbing
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Facuet is loose on counter top how can I tighten
under the sink where faucet is unless lot of clearance use channel lock [adjustable pliers] or if like 99% only enough room for a couple of fingers you will need a basin wrench most hardware/home improvement stores carry it usually under $15 or ask around to borrow one that will get u up to faucet hold down nuts
Oct 14, 2009 | Grohe Plumbing
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Faucet is loose where it attaches to the counter
No; but they make a thing called a basin wrench which is not expensive that makes it fairly easy to tighten for the bottom.
Jan 31, 2009 | Plumbing
Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Dec 10, 2008 | Grohe Plumbing
Plumbing Logo
147 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
