SOURCE: my cannon a430 is blind!!!! i can't see anything
This means the lens sensor is spoiled due to over exposure to heat. One has to give it to cannon service centre.
Testimonial: "Hi, thanks for the advice..but just wondering cause i seldom use it..i noticed a small dent on the portion near the lens ..can this be the trouble?"
SOURCE: CAMERA IS BLIND!!!
MAKE SURE THT YOU DON'T HAVE YOUR FINGERS IN THE WAY IF NOT THEN CONTACT THE CAMERA'S CUSTOMER SERVICE NUMBER OR GO TO THE CAMERA'S OFFICIAL WEBSITE
SOURCE: when trying to take a pic, I only get a black LCD
Try pressing the DISP button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place to save batteries.
That normally fixes the problem of a black screen, but if it didn't, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
SOURCE: When I turn the camera on and look through the
I have the exact same problem.
It started with the recurring "change batteries" problem - which was solved by using non-rechargeable batteries.
Now everything is working fine except there seems to be no light coming through the lense. Everything except reviewing mode is black and all my pictures are completely black. I dont know where the problem is. Could be the ccd. Might take this to the camera shop but im expecting it will cost over $100 to fix... any help?
SOURCE: I have a canon A430 and memory card shows full
Connected the camera at pc with the USB cable, open the explorer program and look the SD card as "external device" open it and check or select all the file in this folde to delete. I suggest first make one backup copy.
Hope helps (remember to rate this answer).
