Hello i have a problem with my designjet 5500, my plotter will not print the file sent i have changed the network card but still nothing on the computer it is saying sent but nothing is picking up on the plotter when i first turn the plotter on it says receiving receiving then ready every time but when a file is sent it will just say ready as if nothing has been sent
Hello.
I have seen this problem on various Designjet plotters.
Try printing an internal test page. If that works ok, the problem is from the Jetdirect card back to the computer. The plotter is not broken
It is sometimes caused by a corrupt printer driver. Try downloading the latest driver from HP and install it on your computer.
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
SOURCE: 1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
SOURCE: Network Connection (LAN) for HP 650C
I have a HP 650C, I just bought a Parallel to USB adapter on Ebay. It can plug straight into a computer and then be shared. I also have network card on a HP 750C+ and have it connected straight to my router through an Ethernet connection and it works fine.
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
