Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
D
David Wagner Posted on Jun 11, 2015
How can I get the belts on? - Craftsman 42 in. Deck 19.5hp Lawn Tractor
How does the belt ranking system work in the Korean martial art of Hapkido?
In Hapkido, there are 11 levels, each represented by a belt color. The order is as follows (from low to high): white belt, white belt with yellow stripe, yellow belt, yellow belt with green stripe, green belt, green belt with blue stripe, blue belt, blue belt with red stripe, red belt, red belt with black stripe, and black belt.
1helpful
Serpentine belt
BELT ROUTING DIAGRAM 1997 Mercury Sable 3.0L SFI 6cyl The Belt Routing Diagram
Fig. Fig. 16: Rotate the belt tensioner and...
Fig. Fig. 17: ... remove the belt from around one of the pulleys to remove the belt
WARNING Use caution when removing or installing the belt and make sure the tool does not slip from the drive belt tensioner or personal injury or damage to the belt tensioner and the belt may occur.
  1. Attach a 15mm socket or wrench to the bolt attaching the tensioner pulley.
  2. On all 3.0L (OHV) engines, rotate the drive belt tensioner clockwise to relieve belt tension and slide the belt off the pulleys.
  3. On 3.0L (DOHC) engines, rotate the tensioner counterclockwise to relieve belt tension and slide the belt off the pulleys.
To install:
  1. Install the drive belt on all the pulleys except the tensioner pulley.
  2. Rotate the belt tensioner as outlined in the removal procedure to relieve belt tension and install the belt onto the tensioner pulley. Make sure the V-grooves make proper contact with the pulleys. Make sure the spring keeper releases or improper belt tension will occur.
2answers
I would like to get a belt diagram for a 1988 pontiac firebird trans am
ADJUSTING V-Belts Fig. 1: A gauge is recommended, but the belt deflection may be checked using light thumb pressure 85341063.gif
Fig. 2: Loosening alternator pivot/adjustment bolt in order to tighten the belt 85341094.jpg Fig. 3: Apply tension to the belt being careful not to damage the case. While holding accessory in this position, tighten the pivot bolt. 85341095.jpg Fig. 4: Using a 1?2 in. ratchet, apply tension to the air conditioning belt while tightening the pivot bolt 85341096.jpg Belts are normally adjusted by loosening the bolts of the accessory being driven and moving that accessory on its pivot points until the proper tension is applied to the belt. The accessory is held in this position while the bolts are tightened. To determine proper belt tension, you can purchase a belt tension gauge or simply use the deflection method. To determine deflection, press inward on the belt at the mid-point of its longest straight run. The belt should deflect (move inward) 3?8 - 1?2 in. (10-13mm). A general rule for alternator belt tension is that the pulley should not be capable of being turned with hand pressure. Serpentine Belt On most newer vehicles, a single belt is used to drive all of the engine accessories formerly driven by multiple V-belts. The single belt is referred to as a serpentine belt. All the belt driven accessories are rigidly mounted with belt tension maintained by a spring loaded tensioner. Because of the belt tensioner, no adjustment is necessary. REMOVAL & INSTALLATION V-Belt Fig. 1: Loosen the component mounting and adjusting bolts slightly 85341064.gif
Fig. 2: Remove the belt by pushing the component toward the engine 85341065.gif
Fig. 3: Remove the drive belt 85341066.gif
Fig. 4: To tighten the belt, pull the component away from the engine and tighten the mounting bolts to specifications 85341067.gif
To remove a V-style drive belt, simply loosen the accessory being driven and move it on its pivot point to free the belt. Then, remove the belt. It is important to note that on engines with many driven accessories, several or all of the belts may have to be removed to get at the one to be replaced. Serpentine Belt Fig. 5: Serpentine belt tensioner - V6 engine 85341068.gif
Fig. 6: Serpentine belt tensioner - V8 engine 85341069.gif
A belt tensioner is used on these models, to maintain proper belt tension. To relieve belt tension, rotate the belt tensioner (using a 15mm socket) to relieve pressure on the belt. With tension relieved, the belt may then be removed from the engine. It is important to note the belt location at each pulley, to assure correct installation, and proper operation of the engine cooling system. A diagram may be helpful in denoting belt positioning. NOTE: Take care not to bend the tensioner when applying torque. Damage to the tensioner will occur. Maximum torque to load belt should not exceed 30 ft. lbs. (41 Nm). prev.gif next.gif
10helpful
2answers
How do i remove a belt from a 2001 hyundai xg300 car
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Accessory drive belt routing—1.5L engine
Accessory drive belt routing—2.0L engines
Accessory drive belt routing—2.4L engines
Accessory drive belt routing—2.5L and 2.7L engines
Accessory drive belt routing—3.0L and 3.5L engine
4helpful
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
To install:
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
2helpful
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
3helpful
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Belts
depends on the engine...3.3 has 1 belt
3.0 has 2 belts a serpentine belt and an ac belt
2.5 has 3belts a waterpump belt an ac belt and a power steering belt
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
