Cars & Trucks Logo
Ron Townsend Posted on Jun 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to program origanal keyless entry remote after dead battery was replaced?
J.J. Feregrino
Level 2:
Loyalty:
Visited the website for 30 consecutive days.
  • Expert 83 Answers
  • Posted on Sep 06, 2018
J.J. Feregrino
Expert
Level 2:
Loyalty:
Answers
83
Questions
0
Helped
93672
Points
493
You should not have to reprogram a keyless entry remote on your vehicle when you change the battery. I know this sounds absurd, but it works sometimes and is worth trying. If you exhausted all of the options above, disconnect both terminals on your car battery for 10 minutes. Then reconnect them and try your key fob. This has worked for many people and I have no idea why. If you do, please comment below to explain.
Vladimir Frolov
Level 3:
  • Toyota Master 2,075 Answers
  • Posted on Jun 10, 2015
Vladimir Frolov
Toyota Master
Level 3:
Answers
2075
Questions
Helped
415536
Points
6445
Dead battery on car?
2answers
How Do I Know If My Car Equipped With A Keyless Entry Remote System? I have a 1999 Ford Windstar. I bought several remotes but can't get my locks to engage. Any help would be appreciated.
Hello Cathy
It does indeed have keyless entry. It needs reprogramming when you get a new remote. Also if you disconnect the battery. Usually a local car alarm fitting shop, or an auto-electrician will do it. Plus of course a Ford dealership.
https://www.google.com/search?q=Keyless+Entry+Remote+System+1999+Ford+Windstar
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
2answers
Why would my battery be draining after trying to program a keyless entry remote with no luck
Just guessing, but maybe your car is still searching for signal from remote? Kind of like when our phones are roaming for signal...
Is there a way to reset keyless entry for 04 endeavor?
Search Results
    2004 Mitsubishi Endeavor Key Fob Remote Programming ...
    blog.keylessentryremotefob.com/.../04/2004-mitsubishi-endeavor-key-fo...
    Apr 25, 2013 - 2004 Mitsubishi Endeavor Key Fob Remote Programming Instructions ... you might have visit us at Keylessentryremotefob.com You can also ...
    Mitsubishi - Free Keyless Remote Fob Entry programming .
    How To Replace Mitsubishi Endeavor Key Fob Battery 2004 ...
    ? 2:04
    www.youtube.com/watch?v=yeQRdre7O0Q
    Oct 31, 2014 - Uploaded by Keyless Entry Remote Inc
    ... will show you How To Replace Mitsubishi Endeavor Key Fob Battery 2004 2005 To Order This Remote ...
1helpful
My keyless entry does not work anymore
Step by Step Solution:
1. Check the battery in your Key Fob/Remote, Replace?
2. If after replacing battery and still does not work then may have lost programming, or bad keyless entry module.
3. May need to take to dealer to have programmed or keyless entry module replaced.
6helpful
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
2helpful
My powerlocks on my mercedes 2000 s500 wont repond to my keyless entry
REMOTE KEYLESS ENTRY BATTERY IS WEAK OR DEAD.YOU HAVE TO LET DEALERSHIP REPLACE KEYLESS ENTRY AND REPROGRAM IT TO UNLOCK OR LOCK DOORS.
How do i program remote keyless entry? I replaced the battery and keyless entry quit working,
You don't normally program a keyless entry, that's done for you by the technicians that install that. If the replaced battery doesn't solve the problem, take the battery and the remote to the techies that installed it.
2answers
My remote for the keyless entry does not work.
does trunk button work? panic button?
here's 2003 info:
  • Driver door module (DDM).
  • Go To Pinpoint Test G .
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2003 Town Car Workshop Manual
GENERAL PROCEDURES Remote Transmitter Programming
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming that the program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat Step 2 within 7.5 seconds.
report back
1helpful
2answers
Keyless Entry Key Doesn't Work
Regarding the remote transmitter issue: Take the remote transmitter to your Toyota dealer. Ask them to test your transmitter with their hand-held RF detector. All Toyota dealers are required to have one of these devices. The RF detector will test the remote to see if it is indeed transmitting the proper RF out of the transmitter, and the strength of the RF signal. If there is no signal, the remote has failed (unfortunatly common), and the remote will need to be replaced and reprogrammed to the vehicle. I do this quite regularly, and rarely do I tell customers taht they need to spend 800 dollars for such a simple diagnosis/fix. The keyless system is very reliable. I rarely change the ECU for the keyless, unless somebody somehow gets the ECU wet, then it def needs replaced. Hope this helps.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
