It sounds like you are trying to register the handset(s) to the base. Once the handset is
charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit
press MENU, scroll down to Display Base ID, press OK, and the Base ID
code will display. If NEW appears in your handset display, press the
soft key under it and enter the base ID code you found in the base
display. If 'New' does not appear on your handset, press MENU and then
scroll down to REGISTER. Press OK and then enter the base ID code. If
the handset is already registered, please deregister all then register
again. To deregister a handset which is registered to the base model
20-2431, Using the soft keys on the base, press the 'MENU', then press
the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'.
Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted.
Press 'SET' . If your handset is registered to the base model 20-2481,
Using the soft keys on the base, press the 'MENU', then press the down
arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the
down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
yes, you got the id though? The phone itself isn't responding at all? Or does it still do something (please be as specific as possible since I'm not there seeing what you are doing) Try removing the battery from the phone to reset it and try again and post more specifics if you still can't get it to work.
Nothing happened. the phone is not responding.
are you there?
