Error message occurs when not in use and states 5 E.
SOURCE: Microwave will not work. Get error message 5E
"SE" error means your membrane keypad is shorted.
We would need the full model number with any suffix in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions.
Or feel free to contact us directly here for free help.
Sometimes it's a simple DIY job to fix this.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
