SOURCE: Samsung 55 inch Smart TV
It sounds that a capacitor inside the circuit of the has failed. It might have bursted. Check the power supply regulator board for the trouble. Normally electrolytic capacitors at this section should be suspected.
This TV has the active 3D transmitter built in to it in some regions. It is included for the model sold in the U.K.
You need to register the Active 3D glasses before they will work with the TV. To register the glasses, turn on the TV and bring the glasses within .5m of the TV. Then press and hold the power button on the glasses for 2+ seconds (until the power button blinks alternating green and yellow). When the registration is successful, a message will show on the bottom of the TV and the green light will stay on for 3 seconds. This will need to be repeated if you use the Active 3D glasses with another TV and then use them again with this TV.
Now you need to activate the 3D feature on the TV. Press the 3D button on the remote or press the control bar on the Touchpad remote and slide the touch pad to the 3D icon and select it. Then choose your 3D option. You may also need to adjust the 3D display settings from the Home button. Press Home and select Settings. Then choose Display and then 3D.
The manual for the KDL-55W829B is available here: http://www.sony.co.uk/support/en/product/KDL-55W829B . The Help Guide, http://download.sony-europe.com/pub/manuals/tvhc/14HE468112-EN-Print.pdf , has the information on using the 3D feature starting on page 56.
I hope this helps.
SOURCE: I have a 55 inch rca led smart tv how can I download apps to my tv
It needs an internet connection.either wifi or Ethernet.then you will be able to choose from the menu within the set.If it's android you can look for googleplay.if it's toshiba or independent make it may run on a Linux o.s.which means you need to use it's built in browser to download or use URL of Internet addresses.
most nowadays are android based o.s. So it's googleplay for apps for which you need a gmail account which is free and easy to create.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
