test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the
turntable motor might be worn out. This is a common problem and
relatively easy to replace.
Touchpad and Control Panel
touchpad and control panel might be defective. This is not common. Test
the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and
the touchpad has a button to turn the turntable on and off the touchpad
might be defective. Check the turntable motor first, that is more
likely.
User Control and Display Board
relatively easy to replace. If the motor is good, the user control and
display board may be defective.
Main Control Board
turntable motor is usually the problem. If the motor is good the main
control board might be defective
