Factory Reset on Proscan PLT7223G or Tablet
go there....and bring a paper clip with you......seriously
Don't forget to plug in the power. And again, press home button and on / off switch, till it switches off. Then press the on / off button, till the Apple logo comes back, then release the button. It can take up to a minute, before the screen comes on.
Testimonial: "On pressing on/off button, the ipad switches off. but when you switch on the logo appears again and stays on.why?"
SOURCE: I forget my password to get into my proscan 7"
If it's linked to a Google account. It should give a option to login to unlock the device.
SOURCE: how do I bypass pattern lock on my Proscan PLT7223G tablet?
Zolygon Factory reset Proscan PLT7223G Android Tablet
Please watch the video and try the link given
SOURCE: user manual for proscan PLT7100G
You may be able to uninstall some of the apps. Go to the applications page by touching the icon with the 6 squares in a circle. Then go to APKInstaller menu. Click (or touch) the Manage option. Select the APK for the app that you want to remove. (Some items may not be removable since they will be part of the OS. They won't have a separate APK installer.)
The manual for the Proscan PLT7100G is available from the manufacturer's product site: http://www.proscanvideo.com/item.asp?itemnmbr=PLT7100G . The direct link to the manual is http://www.curtisint.com/html/custservice/manuals/PRO_PLT7100G_ENFR.PDF . The uninstall information is on page 17 (page 18 of the PDF).
I hope this helps.
A soft-reset won't work. Someone turned on the encrypt storage option, so the proper password needs to be supplied for it to work.
Unfortunately once a password is set you can't use the device without it. You need to do a Factory Reset (which will wipe all data and settings) for the tablet to otherwise work.
How to do factory reset on Android CNET
