Question about MasterForce 12 Volt Lithium-ion Battery
I brought a 3 pack tool set from Menards a drill, a saw and a flight light that the the 12 Voult
I cannot find the correct saw blades to fit the saw I need the Serial # for the sawblade
  • 4,062 Answers
Google search the brand name. They will have saw blade sources.
Posted on Jun 05, 2015
6ya staff
SOURCE:
I need a repair manual for a trade master 9" bandsaw model Pr13102
Is it the right blade?
Who makes Trademaster tools? - Canadian Woodworking and Home ...
https://forum.canadianwoodworking.com/showthread.php?...Trademaste...
Feb 15, 2010 - 13 posts - ‎12 authors
Can you get parts for them? Is $250. a fair ... Home Hardware has been sellingTrademaster for a couple of years. ... It's identical to many other models. ... I still own my 14" trademaster bandsaw. ... 02-16-2010, 03:38 PM #9.
Woodworking - Band Saw Setup and Tuneup - YouTube
? 13:04
https://www.youtube.com/watch?v=ZnqsEszw6xM
Apr 12, 2011 - Uploaded by WoodWorkWeb
Setting up a band saw correctly is an important set in order to get ... Woodworking - How to Adjust for Band Saw Blade Drift -Workshop ...
Jan 21, 2016 | Blade Saws
How do you true up the blade on the 12" compound slide mitre
some saws don't set up when select 90 degrees , unplug saw then take a small square like a combo square , place it against the side of the blade and flat down on the bed of the saw adjust to the square regardless what the setting shows take a fine black marker and put a small dot on the indicator that is on the saw then you know where your true 90 is and always use the dot . should do it even some expensive saws are not perfect i always check the all before cutting if havent used saw before
Jul 13, 2014 | Drills
Replaced blade but saw does not generate any torque. Why?
is the blade fitted correctly and tight enough the motor may be spinning with out the blade
May 30, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Saw blade improperly installed, both washers on outside of blade and can not unsrew
does this tool have a spindle lock? what I would try if not is putting the blade on a block of wood and using the drill and a socket adapter to loosen bolt, if appears from the picture that this might be a left hand bolt, this should take care of your problem. Let me know if you need more assistance and if you do give me the saw model number so I can find a schematic.
Feb 27, 2011 | Ryobi 3-piece 18V Drill / Circular Saw /...
NOT CHARGING BATTERIES
ok you need to zap the battery, if you have a jump box or a battery charger that has at least a 20 amp or better charge selection, like a engine start feature.
the post of the cordless batter has a center post marked on the sides is a plus or minus sign.
the should also be some vertical slits in the plastic post on the corners, clamp the leads from the jump box or battery charger positive to positive , negative to negative. with the car battery charger you can probably slip one side of the battery clip in the plastic slot the other on the connection blade. plug in the battery charger and let it on for 5 or 6 minutes. if the battery charger has a auto shutoff the light will blink off and on but that is ok .
take the cables off and plug into the battery pack charger now you should get a red charge light and now can charge the battery.
if light does not come on try it in the drill or saw and see if you had any more charge than before if so you might need to repeat the procedure and leave it on the car battery charger a little longer
Jun 08, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
MasterForce 12 Volt Lithium-ion Battery Logo
637 people viewed this question
Top MasterForce Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a MasterForce Saw Expert? Answer questions, earn points and help others
