Sony VPL DX 100 is a native XGA projector [1024x768]
so if u connect to a PC that has higher resolution than XGA , it will not be able to project and will show u out of range .
you will need to reduce the screen resolution in your resolution settings to XGA and the problem will be solved.
On a Laptop however, the graphics card should automatically identify the native resolution of the projector and adjust the screen resolution that is being sent from the graphics adapter.
you can also repalce the VGA cable and check if the problem gets solved as a broken pin or cable internally can also result in a similar problem!
