Samsung Model UN60EH6000FXZA. Only 19 months old -Picture went out, sound is perfectSamsung Model UN60EH6000FXZA. Only 19 months old -Picture went out, sound is perfect
You can't post conmments that contain an email address.
Please switch hdmi ports and check for the picture again. You can also do a power cycle (restart) on your tv by unplugging it for 1 minute and putting the plug back in.
If these techniques do not work, please double check that your brightness is not 0 in your display settings.
If all else fails, you can attempt a factory reset.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Sounds like you will need a new power supply board you can get the power boards from www.tvrepairworld.com which also has instructions for replacing the board. Just hit the contact us button on the right side then enter your model number and symptoms a samsung tech will respond via email to assist you with the issue.
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
1) When the picture "stops", does the standby light blink at all?
2) Can you post the model number please?
Some of these sets are known to have problems with the picture tube as it starts to age. There are some workarounds for this that can extend the life of the set for a short time. Without the model number though, I can't confirm that this set is in that catagory. Please supply responses to the issues above and we'll continue from there.
Each set is somewhat unique in terms of parts, could you please update this with the model number. With that I should be able to rpovide you with details.
Thanks,
Dan
