Panasonic KX-T7433 Phone Logo
Joseph Anderson Posted on Jun 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I cancel call forwarding? - Panasonic KX-T7433 Phone
Les Morrison
Level 2:
Sergeant:
  • Expert 209 Answers
  • Posted on Jun 03, 2015
Les Morrison
Expert
Level 2:
Sergeant:
Answers
209
Questions
0
Helped
61356
Points
834
Generally by pressing *72 on the handset
you can check this link for your provider
1helpful
How do I cancel I am here from the station I set it up (mitel phone) or from the station I had forwarded (analog)?
If you forwarded the analog to the digital you probably used a feature access code. So this code will either turn it off if entered into the forwarded phone. Or there is a call forward cancel fac that would turn it off. There may be a clear all features code that programmed that would cancel the forwarding as well. All of these options would need to be dialed from the forwarded (analog) phone.
Cancel call forward
to cancel intercom call forward press the call forward key again or feature #4
to cancel a line call forward choose the line and dial *73 or whatever the phone company's cancel call forward code is (may be in phone book)
On asus fonepad how do i cancel call forward
Hi Phil,
Please speak to your network operator to cancel call forwarding for you or they would give you a command which you would need to enter in your device dial to cancel the same if the software is not allowing it.
Hope that helps !!
T7316 phone does not cancel call forwarding
#73 is a a feature you use on a telephone line to cancel call forwarding (cfw) of an outside call (some codes may differ). You need to have the dial tone of that outside line to cancel the cfw. to cancel the cfw of a norstar set (internal calls to extension) just press the cfw key or press 'feature #4'
Call forward
How did you set up call forwarding? If it involved pressing *72, then try pressing *73 to cancel. If that doesn't do it, contact your telephone company for instructions regarding call forwarding.
Canceling call forwarding from one extention to another
On the extension that is forwarding use Feature #4 to cancel the call forwarding unless it is programmed under the capabilities section in programming. This will require someone with programming ability to make the forwarding change back to the voice mail access number.
1helpful
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
1helpful
Cancel forward
The most common star code to cancel call forwarding is *73
If that works, be sure to hit the "thumbs-up" button for me.
If it doesn't, post back here and tell me who your phone service provider is, and I can look up their call forwarding codes for you.
3helpful
Call forwarding nec elite
Usually there are codes for call forwarding and forwarding cancel. I always program up *8 for call forward and #8 for call forward cancel. On your phone try a few numbers. First try *1 make sure you are on a phone with a display. Read the display and see what it says. If it is not what you need hangup. Then try the next number *2. Remember the #_ is usually the cancel.
Good Luck
Jerry
Fax forwarding
Function 7 set
54 set
1 for invalid set
stop
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
