Getting sense this was designed as a disposable radio - nearly impossible to pull it apart. Volume went dead 2 days ago after 5 years of faithful service. Everything still works - and it still tunes in the stations, but zero volume at all - theres the faintest of a buzz when a station tunes in. I've got nothing to lose, so i want to pull it apart and see if its a bad wire to the speaker assembly - anyone ever taken one apart? Kept pics? there are 2 small screws on back, they dont appear to hold anything in place! im now at the point where I'm stuffing a screwdriver in to the front circular assembly piece
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Mine had no volume and the clock's time was changing randomly. I unplugged it for a night and it still behaved oddly. I unplugged it for over a week and upon reading Mr. Castillo's post, connected the radio to power and it is working properly without doing anything. Curious to see how long it will go.
It has reverted to the no volume state again and does not reset even after being unplugged for several days and trying the reset posted above.
SOURCE: The radio, one station is
Regards,
Tony
SOURCE: Volume won't go past 30
Turn on. Set volume to 00. Press & hold the volume knob for about 10 sec., until you hear a beep. Then turn volume up to the maximum that you would ever want, and then press the volume button again. It is now set.
