Other option is something has come adrift inside. Get a good DIY person with electrical knowledge to trace the main plug, cable and connections. If that fails to show something then move inside and check things like the motor brushes for wear, broken wire etc.
The most common problem when a vac is working perfectly and then won't work the next time is a bad plug. You can get a replacement plug at a hardware store and replace it or take it to your local vac shop for repair. The plug that you put into the wall outlet is what I am referring to.
