SOURCE: my cub cadet lt 1045 starter spins , but doesnt
try to lube under starter gear if still not moving need to have starter rebuilt or replaced
SOURCE: I have a cub cadet LT 1045 and every so often the
There are a few possibillites: a bearing is starting to go on the quill assembly or idler pulley; the PTO on the engine is heating up and quitting to work until it cools off; or you may have a switch going bad. I would look at this first.
HTH
Good Day
SOURCE: Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
SOURCE: motor will not turn over by the key switch on my
When you jump the starter, you are bypassing the safeties.
Check the neutral/brake safety and the blade disengagement safety.
Gary
