Iver johnson single barrel champion shotguns with a single letter suffix to the serial number were manufactured between 1920 and 1929. it seem that most of the 410 were used quite a bit and very few are in excellent condition. the original finish was an oil finished stock, browned barrel and case hardened frame.
CHAMPION MODEL 36--------------------------------1909-1922
Single barrel; rebounding center mounted hammer; top lever operated break open design; gauges: 12, 16, and 20; barrel length: 28, 30, and 32 inches (features barrel and lug forged in one piece) bored full chock only; American black Walnut but* stock and fore-end; automatic extractors; weight 6¾ pounds; overall length with 30 inch barrel 45 inches; case hardened receiver (nickel available as option), browned barrel; automatic ejectors extra cost option; .410 bore, 24 and 28 gauges offered in 1913; 24 gauge dropped 1928; all gauges except 12 dropped after 1941; name changed to Champion single Barrel in 1917.
CHAMPION SINGLE BARREL---------------------------1923-1978
This is the same gun as the earlier Model 36 champion except that the smaller gauges are now built on the same frame as the large gagues. See above picture for specifications. The exact year production stopped has not yet been determined. Some of these single barrel shotguns have been seen with Canadian marking, these were most likely shipped to Canada and then marked as there is no evidence that Iver Johnson's Arms & Cycle Works ever had a manufacturing factory in Canada
SOURCE: I have an old H&R1871 Topper shotgun patened in feb
Yes you can, those old shotguns were pretty much all the same, a lot of the parts interchange, but go to gunparts.com, they have everything there, if not, find Jackfirst, He has a ton of stuff. I have the same gun right here that was my fathers, bought in 1913 for $13, almost 100 years old!!!
It should be stamped on the barrel. If not, please take it to a gunsmith. He should be able to tell you what lenght of shell can be safely fired from the gun.
SOURCE: what year was this shotgun built? serial number 134047
Brand? Model? Gauge? Need these, especially the brand and gauge
SOURCE: what year was my model 42 410 made?
Late 50s to mid 60s that's the best answer I have hope it helps
SOURCE: Iver johnson 12 gauge single shot breakdown. Serial number 7546....what is this gun worth
Would need more info these guns can range from $100 - $1000 some $5000 + depends on age, condition, model, etc... this is a good site to try and determine what you might have.... http://www.gunsinternational.com/Iver-Johnson-Shotguns.cfm?cat_id=632
