Sangean DT-120 CLEAR Pocket AM/FM Receiver DT120 CLEAR Logo
L
Luis Gerena Posted on Jun 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My radio shuts off after 5 seconds.How can I fix this?
Mister Danger
Level 3:
  • Sangean Master 5,631 Answers
  • Posted on Jun 02, 2015
Mister Danger
Sangean Master
Level 3:
Answers
5631
Questions
0
Helped
1199151
Points
47629
Maybe you have a timer to shut it off in 5 secounds? Check your user's manual
Radio shuts off after 5 seconds
I'm not sure what radio option you have in your vehicle or if you have any aftermarket equipment installed to interface radio functions or operations. But if it is the Mark Levinson set up, the software that controls the the function that you are having problems with, is possibly corrupted and radio may need to be reprogrammed at the dealer with new updates/calibrations so it can stay in communication with radio amplifier and all other options including the HVAC system controls. For being a 01' model, this car was way ahead if its time!
2006 bmw 525i shut down radio after 5 min. when ignition is on and next day some problem.
radio is telling you it time for replace it.The or to fix it the radio relay is probably burn or not working right.
Scanner keeps shutting off
Is it a 528 ? Mines doing the same thing ,,,can't figure it out
I own a 2007 chevy cobalt and the digital odometer went out. When I get into the car the odometer comes on for about 5 seconds but then quickly goes off. What is wrong with my odometer and how can I fix...
that is a dealer only part
the vehicle is picking up a fault in the unit and shutting it off this can
be caused by the installation of a aftermarket radio most vehicles
have an illumination wire that goes to the radio to dim the radios
display along with the backlighting for the gauges, the dimmer is somewhere around the headlight control. if this wire is grounding out
on the radio or anywhere else that could be the result.
HP M370n System fan failure will shut down in 5 seconds,
Return to the person that replaced the fan. Obviously it's not fixed.
I just bought a 2010 Camry and the radio display keeps going out or just shutting the radio off completely. Occasionally the screen will say crazy things and then it will work again. Any one have any idea...
hi how are you, sounds like a defective radio, you may want to try this, locate your fusebox and try removing the radio fuse, wait about 5 seconds then put it back. your owners manual should have the fuse diagram and location. if all fails its probably cheaper to replace the radio with an aftermarket one. there are 2 parts you'd need in order to replace the radio, i listed them here just incase . hope this helps. http://www.ebay.com/itm/2007-2011-Toyota-Camry-Stereo-Radio-Stereo-Dash-Kit-Harness-2008-2009-2010-08-09-/130817365850?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D4232088445737875702%26pid%3D100011%26prg%3D1005%26rk%3D5%26sd%3D130790525477%26
4helpful
2answers
Satellite P35-S611 (PSP30U20H001) PC Notebook: what causes the p 35/30 shut down as soon as you t...
The processor is over heating. I have a p-35 s6053 and it used to do the same thing until I fixed it.
Do the fans come on or anything when you first try to turn it on ??????
I'd bet the fans come on strong and then after about 5-60 seconds it just shuts off. let me know if i'm right and I can tell you how to fix it,
Top Sangean Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
k24674
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
