The light went out how do I replace it - Daewoo KOR-7L0B Microwave Oven, White, 0.7 Cu.Ft. Capacity, 600 Watts of Cooking Power, Electronic Touch Controls, 10 Power Levels, Electronic Child-Safety Lock, Exclusive Concave Reflex System C.R.S, 59 Min 90 Sec Cooking Timer, 5 Menus Auto Cook, Auto Def
In this case, you have to check the control panel. There might be wire connections and contacts that loosens. The bulbs inside the oven is connected to a switch that that only functions once the oven is in closed position.
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
The controller needs to be repaired.
We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board.
For safety, disassembly and other info see http://tinyurl.com/yzjozk
