Garmin nuvi 260W GPS Receiver Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nuvi350 doesn't locate any satillites. What can I do?
Harry
Level 2:
  • Garmin Expert 343 Answers
  • Posted on Jan 27, 2010
Harry
Garmin Expert
Level 2:
Answers
343
Questions
0
Helped
192153
Points
617
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
My Panasonic viera tv will turn on and off but no other buttons work On the remote or on the tv itself
Try unplugging power cord for 10 sec. or for over night. That might be the trick. I did the same trick on a satillite receiver and a DVD player that got stuck like your tv is doing and it worked, doesn't hurt anything to do so. Hope this helps.
Cant unlock nuvi350 na
If you go with-in 50 meters of the Security Location you programed your Nuvi the unit will automatically unlock... most are at your Home or Work areas since you would have to had called them to set it up.
I cant unlock my garmin nuvi350 keeps asking for my pin i dont even remember putting in a pin i dont know but i really need help please someone thanks
the only way to unlock a gps is to return to the security location (where you put the pin in for the first time) or return the unit to garmin to get it reset.
Nuvi350 won't power on from USB or power jack, works fine in car
Bad contacts with the mini USB port. Either the connector needs resoldered or replaced. Please see this link, section on loose/broken USN port:
http://www.sharc.net/gps_charger_repair.htm
- Jim
1helpful
My daughter has a nuvi350. She used it to get to a location away from home and now it will only show that as her starting location, We have deleted all locations and the unit shows the same coor. wherever...
I am not entirely clear of what your problem is. But i assume you have set your home location, hece that is why the map always uses that reference to start from.
If it doesa not advance beyond that point when travelling to a new address i can only assume you have no satellite connection.
This is caused by a few things, but the main one is battery level. Make sure its fully charged.
second point is you do not have a clear sky view.
3rd point is you have blown the SIIRF chip lets hope its one of the two minor ones I mentioned
Garmin nuvi 300
did you changed any setting in your device.if no then it could be the antenna nor receiving proper frequency.
Dvd recorder to satillite
if your dish satellite has an extra A/V output or if your plasma tv has the outputs and the recorder has the same type input AUDIO/VIDEO jacks
2answers
Garmin not acquiriing satillites
hi
possibly the unit is set to 'use with gps off' mode
go to the satillite page and hit menu
select use 'gps on' then enter
make sure you let it re-find the satillites again before you move off
D
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
