Hello, I need help when I try to sew my bobbin is getting caught somewhere around the shuttle hook outside of the bobbin area and it doesn't let me sew,when I do the first stitch a funny sound. I have made sure I've done everything correct but I looked and refer to the manual and it said shuttle hook could you please help. I hope I have somewhat explain it right, also I did try to remove the shuttle but I don't know if I need a special star screwdriver I tried to loosen the screw but didn't want to strip it. any help would be appreciated.
Barbara,
Upper thread looping around the shuttle is typically caused by improper threading through the upper tension disks and takeup lever. Check the instruction manual, carefully rethread the top of your machine and make sure the presser foot is in the down position. If the problem continues it may indicate an issue with tension disks. Remove the upper thread, fold a clean piece of fabric and with the presser foot raised to open the tension disks, place the fabric it in the thread path, through the upper tension disks. Lower the presser foot and draw the fabric back and forth to clean any build up of grime and wax from the disks. Lift the presser foot, remove the fabric, rethread and try again.
If the problem persists, you should not need any tools to remove the shuttle to inspect it - sometimes it is necessary to remove the needle plate to lift it out. Check the edges and underside of the plastic shuttle for marks caused by needle strikes - these can catch the thread causing the issue you describe. If there are marks, you may be able to polish them out with fine (600 grit or higher) wet and dry paper. I generally replace them. Also check the tip of the hook for marks - you can often feel these with your fingernail. If they are present, you may need to get a mechanic to polish them out.
Testimonial: "Thank you so much! you were right! I wasn't threading the proper way,I was so concern with this and really wanted to fix the problem. Well I confimed what you told me by taking it to a repair shop and I was told exactly what you said. The lady threaded the machine and the machine started sewing beautifully! there nothing wrong with tension or any like that just improper threading and the best part was that I was not charged!! Thank you so much for your help. People this person knows what he's talking about."
