Computers & Internet Logo
Posted on Jul 11, 2009
The touchpad on my gericom laptop has stopped
The touchpad on my gericom laptop has suddenly stopped working.I think it was Elantech? Do i need to download a driver? I can use my wireless optical mouse with no problem to use the laptop but the touchpad is dead!
Have looked in device manager and nothing is listed also the Elantech icon has gone from the taskbar
help !
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 14, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
787
Points
Simple solution, turn off all power to laptop,(remove power cable) then removethe battery,replace the battery, power up,the laptop will reboot your touchpad drive, and it will be as normal,I have a Gericom 1580 xl+ which this fault appears fairly often, this method always worked for me lordy
My acer laptop 5742G not working scorlling
Check the touchpad driver in device manager: control panel>hardware and sound>device manager. Look for; mice and other pointing devices and expand the menu. You should see the touchpad driver here (synaptics or elantech) right click on it and click properties and check that its working properly in the general tab. On the drivers tab, click update driver and search automatically for updated software. If the driver is not installed or has become corrupted, you can follow this link to download and install a new driver: http://support.acer.com/product/default.aspx?modelId=3278
2helpful
Hi, I need help with my acer aspire 5750, the Multi-Touch Touchpad has stopped working. It works as in its moves the cursor on screen but the secondary touch control that controls; Circular-motion...
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
My multi touch pad is not working. how can i redeem it again?
You need to go to ASUS's website and find their downloads in the support section. You need to use the chipset, touchscreen, and acpi drivers. The XP drivers will work in win vista and windows 7. You will also want to get the elantech touchpad configuration utility from them. The chipset and acpi drivers will also make your function keys work.
2answers
My brand new ASUS 1015 PE netbook has a habit of frequently moving the curser while I type, so that sentenses are completely messed up. Sometimes whole sentences are randomly deleted oranew page pops up....
  1. Turn it off While Typing:
  2. Press Fn key (left of spacebar) while holding the Fn Press F7 key
  3. Fn + F7 turns off your Touch pad
  4. Fn + F7 turns it back on
Thank You For Choosing FixYa~!
Mouse of the laptop got locked , what shal i do to unlock it!?
To enable the TouchPad; Open the Control Panel > Mouse > Elantech > Highlight "Elantech Smart-Pad" then click on Start Device".
Tick "Display Dynamic Icon" to make is easy to Enable/Disable in future from the Task Bar.
hope this helps!
2answers
Have a Dell Latitude laptop and the touchpad just stopped working
For some reason most latitudes have this problem, I don't know why but its some problem with both the software and hardware setup.
Eee PC with elantech, how do I get the normal functions back
Hi!
To solve the problem you have to go to cintrol panal and ther is an option for touchpad and you can change the setting from there as per your preferance.
2answers
Elantech smart-pad problem
The elantech settings have a box you can check to disable the pad while typing. Uncheck the box if it is checked.
3helpful
2answers
Touchpad has no tap, left key not working.
I had this issue and resolved it by doing the following:
-Open the start menu by using the windows button
-Use the arrow keys to highlight run and press enter
-Type 'control panel' and press enter, find the mouse properties and enter
-From the buttons tab in mouse properties, go to double click speed and change to slow and confirm the changes
-At this point it probably still wont work, so do the above again but change the double click settings to fast and confirm.
-Restart your PC and this should resolve the matter. you can alter the double click speed again if you wish :)
Hope this helps,
tbo
Grand Canyon Tech
Grand Canyon Tech
