I have filled new developer in my Sharp 5520S copier, but developer spills out, every time I start the machine.
Did you clear the require counter and run the required test before (counters) and test after ward????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
SOURCE: sharp ar5320 developer reset code
The developer doesn't have a reset code. It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days. You should order some developer.
SOURCE: developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
SOURCE: toner explosion
You need to either replace the toner cartridge or empty the sump on the front of the cartridge. The waste sump is in the front of the toner cartridge, It has filled up and has nowhere else to go but out of the sump and where ever it lands. Sometimes they fill up before the toner cartridge is empty. It happens
SOURCE: new machine sharp ar 5320 developer installtion first time
Whats your question here, are you needing help with installation or connecting or is it not functioning after installation
