Changed out control board but holding down "End of Cycle" button still does not release controls
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
SOURCE: dryer wont start
Commonproblems...blown house fuse, broken belt ( on some models
)...door switch...*thermal fuse open (venting needs attention
)...broken or burnt wire....timer....motor, in order from mostcommon to
least common. * If you find a blown thermal fuse, always clean, change,
adjust the ventingsystem and vent hood first, then it is often a good
idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: The control lock light will not go off and the
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I plug it back in the control lock light come back on. Whirlpool Duet gew9250plg
SOURCE: Control locked on my Whirlpool Duet GGW9250PW0.
(Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Whirlpool Duet gew9250 - Control Lock
The most common reason for this type of complaint would be a failure in the user interface board (UI), if the portion of the board has a short circuit across the lock trails it will demonstrate this symptom.
The fix would be to have the UI replaced. Part number is
8558753 Platinum
8558755 Biscuit
8558756 Pewter
The cost for the part alone is around $160.00 plus labor to install.
I know this is not good news. sorry....
SOURCE: I have a whirlpool duet dryer - the control lock
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Instructions below:
