Can you show me diagram
Hi Kenneth:
If you've got the right replacement belt, you should be able to install it using this technique.................
- The LAST pulley to fit will be the SPRING LOADED TENSIONER
- The grooved side of the belt is the INSIDE and it will go on the Outside of all grooved pulleys.
- The smooth side of the velt is the OUTSIDE and will go on the Inside of all smooth Pulleys.
- Just a bit of patient fun...... Thread the needle..... In/Out?In?Out
Last one... The tensioner...Use the flex bar... fit in the square hole... Pull..... slide belt over..... release tensioner. Ta Da!
