:::Updated Post::: To further explain my situation, three months ago I unplugged one 3-pronged plug to the Control Board (part # 8205237) of my Whirlpool GH6177XPS-5 microwave, and thinking it would be obvious where it went, I did not note it. But when i revisited it last night, I noticed that there were three receptacles on the board with no connecting plugs. Two of them were the same 3-pronged type (P3 and P27) and one was 2-pronged (P26). However, there were only two loose plug / wires - one 3-pronged and one 2-pronged. So now I can't remember where the 3-pronged plug went (P3 or P27), nor do I know if the 2-pronged plug is meant for receptacle P26 and was accidentally unplugged, or is designed to be left unplugged (I'm thinking not, but want to be sure). My microwave's 1100W inverter is not working, so it's not like I can test the different combinations. :::Original Post::: I recently removed the control board part # 8205237; http://ecx.images-amazon.com/images/I/5136H51gmrL._SL1000_.jpg to my Whirlpool GH6177XPS-5 microwave without correctly noting the wiring connections. I'm specifically looking for help with connections P3, P26 and P27. What wires connect to them? Are any of these supposed to be left without a connection? Has anyone been able to locate a wiring diagram?
It should be all different sized plugs,but,im probably wrong here is all the info i found, Control Board for Whirlpool Microwave Oven Part 8205237
8205237 CNTRL ELEC
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ab0878b6da42658f85256de100560ffb/%24FILE/EOC.pdf
Whirlpool Microwave Schematics Bing images
Testimonial: "Thanks Johnny I appreciate your reply, but I wasn't able to find an answer from your links. - To further explain my situation, Three months ago I unplugged one connector / wire to the Control Board (3-pronged) and thinking it would be obvious where it went, I did not note it. But when i revisited it last night, I noticed that there were three receptacles on the board with no connecting plugs. Two of them were the same 3-pronged type (P3 and P27) and one was 2-pronged (P26). However, there were only two loose plug / wires - one 3-pronged and one 2-pronged. So now I can't remember where the 3-pronged plug went (P3 or P27), nor do I know if the 2-pronged plug is meant for receptacle P26 and was accidentally unplugged, or is designed to be left unplugged (I'm thinking not, but want to be sure). My microwave's inverter is not working, so it's not like I can test the different combinations. Again, thanks for your help."
i just found this,you might find something that is close to ithttp://adcxns1.whirlpool.com/Service/Srv...$FILE/8178743.pdf
