Food Mixers Logo
M
Michael Dickenson Posted on May 28, 2015
I am looking for a carlsbro 1500 mixer amp user manual download
Hi, I have a Carlsbro Marlin 1500 mixer amp and am looking for a user manual please. Michael
2 Related Answers
Bruce Showalter
  • 133 Answers
  • Posted on Mar 23, 2008
SOURCE: I'm looking for a gemsound CDM-150 mixer user manual (instruction book).
Here is the website for Gemsound:
http://www.gemsound.com/products_cdplayers_cdm150.html
Anonymous
  • Posted on Apr 15, 2010
SOURCE: Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
I have lost the manual and need the directions for use of the Kitchenaid mixer 5 quart
HI JWPERCY14223. It is very easy to download the
The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and select “Consumer” for User Type, then enter the 6 character model number, in this case K45SSW, and then select the first file under Owners Manuals (2) K45SSWH-0.pdf (2730.37 KB) (be sure to check that it matches your mixer).
The first file is the full 86 page ‘Instructions and Recipes’ manual in English that was originally included with your mixer. The second file is a 60 page multi-lingual (English, French and Spanish) Instruction manual without recipes.
While you’re downloading the Owner’s Manual, I would recommend downloading the accompanying Part List Manual, too. Select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) and save that on your computer. If your ever have to troubleshoot or repair your mixer the Parts List manual will be an invaluable document to have on hand when taking your mixer apart and reassembling it.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer for your future reference, too.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! – hslincoln
1helpful
Replacing the brush
Hi DENAULTR, this is a repeat of my previous answer to your problem. It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model. Turn to pages 6 & 7, titled ?Motor And Control Parts?, which provides an exploded view for the disassembly and reassembly of your mixer?s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively. Make sure you orient each bruch correctly following the illustration here: The Parts List diagrams along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA If this solution has been helpful to you, please rate it, thanks! -hslincoln
3helpful
I need the manual for my K5SS mixer my
Hi WWW_SOCRAFTI, you can easily download both the Owner’s Manual and Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50PPWH0.pdf (5156.65 KB) from the Owners Manuals (9) list and this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
The reason I suggest downloading the Parts List manual is that should you decide to try and troubleshoot and fix your KA mixer, this manual will be invaluable in the disassembly and reassembly of your mixer along with listing all the part names and numbers. Having the correct part names and numbers is critical when reordering replacement parts when your mixer eventually will stop working.
Good Luck with your mixer, I hope this helps. Howard, Burke, VA
5helpful
New mixer did not come with manual
Hi MITCH, Happy New Year! Somebody at Sunbeam must have been asleep when the mixer passed by on the production line...duh? I hate when that happens. The good news is that you can download a PDF Users Manual from the Sunbeam website. Just click on this link Heritage Series 2353 Mixmaster and look for your M-I-L’s model to about ½-way down the page. Open the file and save it to your PC.
I’m not very keen with the way Sunbeam lays out their User’s Manuals. You’ll need to do some editing and repaginating to get it into a format that your M-I-L- can use, but at least you’ll have it. You can send it to her electronically or print just the English pages and mail; your choice.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
1helpful
I didn't get a User's Manual with my KSM90 Ultra Power Blender.How can I obtain one so I can start using my new blender?
Hi RSTOCK7. You can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KSM90PS, and select the last file listed that appears under Owners Manuals (20): KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it.
After downloading your Owner’s manual, I strongly recommend downloading the last file listed under Parts List (16) manual, too: KSM90PSWW0.pdf (354.08 KB).
The Parts List manual provides exploded view diagrams for the various assemblies of your mixer along with the part names and numbers so you can order repair parts and replace them yourself when your mixer goes out of warranty; one year from purchase date.
You can print both files and keep them in a binder along with your cook books or keep them electronically on your computer to look at when ever you need to reference them.
Good luck, I hope this helps. Howard, Burke, VA
Jan 14, 2010 • Food Mixers
6helpful
I an looking for the intructions on my Kitchen Aid mixer. It's 250 watt, 10 speed. I cannot wait to use it!
Hi. Goto kitchenaid.com. Click on the Customer Care button, click on find manuals, in the search window, enter k45sswh. this page will show the operating manual and farther down the page the parts manual. Download both these files.
Go to mendingshed.com and locate their FREE kitchenaid service manual and download it. This manual will greatly assist you or a repair person should your mixer ever need repair.
A word of caution...Do not overload the mixer with too much bread or cookie dough or it will cause damage to the transmission. Use the recommended capacities found in the manual.
If this solution has assisted you, please rate it. Good luck! ricardok45
LOOKING FOR RECIPE FOR MAKING BREAD DOUGH IN MY KITCHENAID KSM90 MIXER. I HAVE NEVER MADE BREAD IN MY MIXER, I DO NOT HAVE A MANUAL.
Hi Manfredi. Follow this link to download your mixer's manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Instructions%20and%20Recipes%20-%209704323.pdf
If this solution has assisted you, please rate it. Good luck, and don't overload the mixer when you're making bread dough. ricardok45
Need user manual for Kitchenaid Artisan Series Mixer Model RRK150 OB serial no. WS 1208816
Looking on the KitchenAid site, your model did not look up, buyt I put miune in and this is the link to download the manuals.
Top Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Food Mixer Expert? Answer questions, earn points and help others
