Estate EED4400WQ Dryer Logo
A
Anonymous Posted on May 27, 2015
My estate dryer model number EED4400WQ0 runs alittle while then shuts of it is heating
  • Anonymous May 28, 2015
    Cleaned the dry out and it's still shutting down any thing else I can try....i appreciate your help thank you
Level 3:
  • Estate Master 19,187 Answers
  • Posted on May 27, 2015
Estate Master
Level 3:
Answers
19187
Questions
0
Helped
4339453
Points
82259
One of the causes of this is OVERHEATING. Dryers are not maintenance free. You have to clean the duct work and under the unit to remove lint. The lint screen does not catch it all. One of the leading causes of house fires is lint in the dryer.
Dryer will run and heat but will not turn
It sounds like your drive belt might be broken you can get a new one if you go to www.repairclinic.com enter in your model number and it should cost around 9$ the other possibility is the tension pulley or if it doesn't sound like your motor is running but most likely the drive belt .
An average load in the dryer is taking about 90 minutes to dry, which I think is way too long. I've check the vent and it is clear and air flowing through. Although there is some warmth to the...
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Dryer-Parts/Model-EED4400WQ0/3191/0151200/W0902062/00003 is an attached layout of your machine.
Usually with your indications it is something with the blower fan. So hot ar is not sent from the heating elecment to the drum. BUT before you start ordering parts, check the simple things first. Check to make sure that the dryer vent to open from the machine to the outside. That would also restrict air flow and cause your indications.
4helpful
My dryer, estate EED4400WQ0 will not turn on at all. checked the fuse box and not tripped. HELP!
Remove the dust cover and the filter chute. See the fuse?
small white component to the right of the blower wheel below:
I use a shop vac to clean out the dryer.
I always take the drum out and clean her up. I use zoomspout oil on
the idler and rollers because it is safe for dryers and heaters too.
I have a service manual and videos of how to get into your dryer HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
No heat, timer not moving
Yes you need to replace the duct fuse and clear all air obstructions. I have repair photos HERE
I have a Estate Whirlpool model#TGD5740. Smells like smoke when running. Still drys with heat and runs fine. What would cause this
You could have a build up of lent inside the dryer which might have ignited. Dryer should be dissasembled and cleaned.
Could be that your motor is over heating.
Depends on what type of smell your smelling;.If its the motor over heating, motor would have to be replaced.
ESTATE DRYER BY WHIRLPOOL TO SWITCH DOOR FROM LEFT TO RIGHT
Look in the whirlpool wedsite for you make and model and for spare parts list.
Top Estate Dryers Experts
Paul Carew
Jorgie  the...
Jorgie the...
Are you an Estate Dryer Expert? Answer questions, earn points and help others
