How do I remove the drum to replace the seal.
When the front door glide system on the fex series dryers wears out the drum isn't held in place properly, there is enough of a gap between the bottom of the drum and the front panel for clothing to get in. As the drum rolls and the item moves to the top it becomes pinched as the gap closes leaving stains and sometimes damaged clothing.
If this is what you are talking about, Make sure it is unplugged then remove the slanted panel above the washer lid. remove the control panel (4 screws) it can be unplugged (2 plugs on left side) and laid aside (rubber line can be removed and slid out of plastic clamp.
when the control panel is removed you will find two screws holding the bottom of the front panel, these have to be removed.
there are 4 screws along the upper edge of the front panel that have to come out and then the front will come off.
Reassembly is difficult with this machine (I remove the dryer door if I'm working alone) so try to do the job when you have help.
Good Luck
Quentin
