To convert a marathon CL030062 (military time) to standard time, simply subtract 1200 from the time and add "AM" to the result. For example, CL030062 in military time is 3:00 AM, so in standard time it would be 3:00 AM.
There are 48 hour settings possible 12AM hours 12 PM hours and 24 non designated (military time). Keep cycling through until the correct hour comes around. Make sure it says either AM or PM if you do not want military time.
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle.
You'll notice that the 2nd time through it is on military time.. 3rd
time through back to 12 hour day AM/PM cycle .. 4th time back to
Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
