SOURCE: need wiring diagram for washburn lyon guitar
Try this site:
http://www.guitarelectronics.com/category/wiringresources/
Find the schematic closely matching the resources of switches, pots, and pickups of your guitar.
SOURCE: i have a washburn lyon
Try this site... find the configuration of pickups and controls and then select that set:
http://www.guitarelectronics.com/c=Ijshs0QUDUCFOzkjYu7hSxoe4/category/wiring_resources_guitar_wiring_diagrams/
SOURCE: Shadow Kill Pot Wiring Diagram with 2 active
Are you using the original solderless wiring? Are you starting from scratch? Are just wanting to install the Shadow pot into an already working guitar? If you are working on an already working guitar Please give the model number, if EMG equipped, So I know where and what we have to work with. But this should be a straight up fairly easy setup. The Shadow pot just replaces the normal volume pot. Off to work, but will be back with you.
SOURCE: Will volume and tone knobs
Yes, Some gibson electric's have long shaft pot's, they will still fit but you will need to use another nut to adjust the pot's so they do not stick through the body to far. Knobs should fit unless the old gibson's are solid shaft. Then you will need new knobs. Many guitar parts places on net to order standard pots and even wiring kits. Try Allparts, , www.guitarelectronics.com/,, Guitar ******, then www.stewmac.com/
