Cell Phones Logo
Evangeline Posted on May 26, 2015
Pls I need volume code 4 blackberry 82220
My music is 2 soft it doesn't want 2 go louder
What's your question? Pls I need the volume code for my blackberry 8220 phone pls nd than
Evangeline: 1. Double check the high profile ringer volume, that the volume for the phone is truly on the highest setting.
2. Do a simple reboot: With the BlackBerry device powered ON, remove the battery a few seconds and then reinsert the battery to reboot.
tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 • Computers & Internet
The media files on my blackberry bold are quiet
Try this,i did,
1.Play some music,so your on the music screen.
2.Once on the music screen,click blackberry symbol button
3.Scroll down to ''Activate Speakerphone'
4.It should become much louder!
Or just try turning it up at the side.
if this does not solve your problem it may already be on that setting,it could be faulty?!,Hope This Helps
1helpful
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
How do you turn the volume down
1. Turn on the cube2. Hold silver + yellow at the same time while the startup music plays3. At the end of the music the voice will say "volume control, volume level ..."4. Release the buttons5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4".6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
How do you turn the volume down .
1. Turn on the cube 2. Hold silver + yellow at the same time while the startup music plays 3. At the end of the music the voice will say "volume control, volume level ..." 4. Release the buttons 5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4". 6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
How do i get the volume up
YES U CAN DOFROM THE SETTINGS GO TO THE RING TUONES AND SCROOL DOWN THE KEY AND CHANGE THE RINGING VOLUM AND U SHOULD OFF UR VIBRATIONS OK BYE U CAN GET U AUTO MATTI CALY
Apr 09, 2009 • Nokia 6230
169helpful
9answers
How to increase volume in samsung E250
Try the code below at your own risk. I will not be liable for any damage this may cause to your phone.
Type the following codes on standby menu
*#0206*8378#
after typing you will be presented to a Test Mode menu
Select H/W Test
Select Audio Settings
Select IIS Normal (option 10) this is the normal volume for the phone. Scroll down to select Rx vol. then change level 14 to a higher value. Maximum is 30,000, i set mine at 5000
You can do the same for IIS Normal2 this is the volume for Music Player
21helpful
6answers
I want to make my phone play louder
*#9998*324#
you can adjust all the settings on the menu.
May 05, 2008 • Cell Phones
Top Blackberry Cell Phones Experts
NOEL
NOEL
john h
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
