I cleaned the oven self clean, now the oven preheat feature won't turn on
When I push the bake button, I usually push the up arrow and it goes to 350 deg, then the preheat button lights up. After using the self clean feature, The bake feature or broil won't go on. Instead of lighting up preheat and going to 350 deg, the LOCK light come on. I have tried locking it, unlocking it...no matter what position the lock feature is on, the lock light keeps blinking, and the oven will not go to the preheat feature.
Unplug the power and cancel it. Never Ever use the self clean feature. We see damage here every couple of weeks. The worst was a burned control board on an oven that all parts were obsolete, so the self clean cost a thousand bucks!
Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (Says Maytag who love selling elements, door locks and other parts),
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
First take out the racks (unless they are coated with the same porcelan coating as the oven interior). Press the Clean or Self-Clean button. Press up or down arrow key - 3:30 will show in display which represent time in hours and minutes. You can press the up arrow key for more time, or the down arrow key for less time, but usually the default time is good. Then just press Start. The door will lock and the oven will turn on. In 3 1/2 hours the oven will turn off, but the door won't unlock for another hour.
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com The
only button on your stove that should make the door lock would be the
clean button (self clean model) if that is pressed simply hit the
clear/off or cancel key and wait for the door to unlock. IF the self
clean option ran for an hour or so, you will have to wait for the oven
to cool down before the lock can unlock (safety feature).hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
Remove oven racks and soak them in soapy water.
Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
Let the oven do its work;it will heat for several hours, charring off baked-on foods.
Fast Cleaning
Remove oven racks and place them in soapy water to soak.
Preheat oven to 200 degrees.
Turn the oven off and spray the inside with oven cleaner.
Allow to sit for 10 minutes.
5
Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
You should have a bake and broil button and arrows to adjust temp up and down. Of course a start button should be there. If no off button, then there should be a cancel button to turn it off. The door only locks in self clean mode.
Usually,
when an oven won't bake, it's because the bake element is burned out.
The bake element is the black, pencil- thick tube at the bottom of the
oven. When the oven heats, the element glows red. This element has an
expected life-span of several years. It may last for only one; it may
last for many more. When the element burns out, you need to replace it.
