Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Hi salinkous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Does this occur while watching a dvd or while watching tv? Try several sources and see if you get the same result.
Only when watching TV
DVDs work fine with no color distortion.
I would switch the cable going from your antenna or cable box to the tv.
