SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
SOURCE: Sony KDL-46XBR4 much darker on the right side of screen
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
SOURCE: VERTICAL LINES WHEN TURNED ON THEN CLEAR UP AND
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
SOURCE: Sony KDL-46XBR4 right 2/3rds screen darker, motion blurred
Hi Ron, thanks for describe many valuable details. You suspect something wrong with the fluorescent tube, if it is true, shall be dark on top or bottom, not left or right, also the problem with the backlight the TV will shut off and the timer LED will blink 6 times.
I think there is the bad connection inside the panel or the t-con board, only think you can do is try to reconnect the wires under the aluminum foil (see the picture) or replace the panel.
SOURCE: black line going down middle of screen and one
if the line is pixel thin, it could be a bad lcd panel. if it is a wider bar, it may be in the video circuitry. many of these sony tvs had bad panels, and sony has extended the warranty. call up sony with your model and serial # and date of purchase and try to get them to help you out, that is your best course of action. let me know if you need more troubleshooting assitance.
