Question about Xerox Office Equipment & Supplies
My Xerox 7228 Workcentre shows Error code 016-311, how can I fix this?
Showing Offline in computer printer status. Ping to printer IP address success. ON printer LCD showing 016-311 error
    Top Expert:
  • Xerox Master
  • 2,153 Answers
6ya staff
SOURCE:
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Sep 15, 2010 | Zebra 140Xi II Thermal Printer
Our Xerox Phaser 8550X Color Printer is showing as
If connected via usb make sure the cable is plugged in and the printer is setup and turned on.
Check the status of the printer on the control panel.
If setup using the network cable, check to make sure there are no IP address conflicts, this can be a common issue. Basically your computer may be looking for the printer in another location and so you keep sending jobs to the printer but it's not responding yet you walk over to the printer and its ready or still in sleep mode. Basically a network setup and not a printer issue.
Apr 28, 2010 | Office Equipment & Supplies
I have xerox wc 7228, when i try to copy it is showing ''A fault has occurred press C botton to cancel '' error 009-936
hello
here is the link Xerox offical site about error codes and things that you can do . i hope it useless.
Feb 10, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
HP Laserjet 5000 moved and now says offline
Please verify the workstation (or server) is not set to "use printer offline", I also suggest trying to ping the ip address of the printer or trying to access the webinterface of the printer by going to printers ip address in a web browser.
Please let me know if this fixes your problem or if I can be of further assistance. Thank you.
Sep 18, 2009 | HP LaserJet 5000n Printer
When I hook up my Xerox WorkCentre to my computer the printer doesn't work. I have tried two different routers. Everything esle works but the printer.
hi
check the ip address on xerox and computer both have to be the same and if u want our technician support contact us at http://tinyurl.com/ldnuy2
Jun 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Sep 08, 2008 | HP LaserJet P2015 Printer
642 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
